Did some work here and there to prepare for the rear canopy glueing. I had to change the rack to clamp the canopy siedwise a little bit to make it more efficient on the clamping process.
I drilled 15 6mm holes into the each square steel tube and inserted M6x100 bolts together with nuts. Now it's a quite quick process to precisely clamp.
